Air In The Cooling System
Location: A Small Island Somewhere In The South Pacific
How do I bleed air from the cooling system?
I can't find any bleed valves or know where to release the air.
Its just a self bleed system i think. The highest point on the system is the thermostat. I have a 2wd burton thermostat housing, which has the second outlet which is blanked off. I usually just fill the system and remove the blanking plug until the air is relaesed and water flows out of it, meaning the system is full between the rad and thermostat. Then I just run it upto temp with the expansion cap off. As long as the thermostat opens as it should the air should just vent off. Oh, and the hot air heaters in the car need to be open.
±§~Quadzackular~§±
I always thought a swirl pot worked from the housing in pic (right side) to the swirl pot then to going to rad, but there is also a small pipe on the top of the swirl pot going back to the header tank for air to escape but once the air is out then fluid would just circulate though the system... I may be wrong though.
Please can someone confirm this!
Johnny Knoxville
30-09-2015 07:21 AM
Russ Payne
25-09-2015 08:29 PM
