stronger driveshafts in uk
Hello friends ..do you know some one in england who makes stronger the front driveshafts not the cv just very stronger front shafts for 4x4 cosworth .thanks
Graham Goode supplies a direct replacement front drive shaft, don't know about the strength of them, front drive shafts shouldn't be a problem as long as everything else on the front of the car is up to scratch bushes, engine mounts and the like
avoid standing on the power when the steering is on lock also helps to stop the front shafts from popping out
Luciano
Luciano
Luciano
Luciano
XR4x4 and Granada 4x4, have 12mm longer shafts ,and thats help stopping right side popping out, but normaly this is not a problem whit upright engines mounts. Don`t think this drive shafts are any stronger then oe ones
markk
18
17-08-2015 05:19 AM
