Braided brake pipe fitting SORTED
Does any one know where I can buy just the brake pipe reducer fitting that is used when putting braided lines on the front, it's the adaptor that converts the std hose size to the much smaller braided size, it gets bolted into the hole at the bottom of the inner wing through which the brake pipe passes.
Whilst working on the car today my dad managed to snap it, or rather the end of the fitting off which is a small nozzle about 3mm, that goes inside the braided pipe that is put on from the leg to the inner wing.
Thanks
SORTED, I had 2 new pipes made without these unions, well with them but crimped on instead of screw on sort, all in SS.
Thanks
track.focus'd
12-08-2015 05:53 PM
