Misfire when hot
Misfire when hot
Chaps getting the cossie ready for its MOT but keep getting a misfire this only happens if its stationary for a while and the fan kicks in, after this it labours and misses all the time until you switch it off and let it cool for a while.
if you are just driving it runs fine any ideas as what the problem could be?
Martin
Martin
Let me guess, you are running a CONE air filter ?
It sounds as though it is running rich, whilst not normally a problem, when the fans kick in and the car is stationary the cone gets flooded with hot air, which has less oxygen, the effect is the fuel mixture gets richer, you can watch this effect on the MOT gas anylyser as well, you'll see it plain as day.
Cheers for the reply tabetha!
Would this still cause the misfire even when you are moving again and getting fresh air? As once its started it continues until you switch off and let cool for a while then its ok again!
Martin
Martin
