Saffy speedo...
Old 12-05-2008, 09:16 PM
BIG WULL
Fae the Dale
BIG WULL's Avatar
Default Saffy speedo...
Ok so i'm trying to be gentle with the new car an not going for the usual bish bash bosh method.... blah blah blah
Does the speedo cable just pull out or screw out or what? at the back of the speedo.
Was at it for about an hour tonight in the garage before calling it a nite.
Old 12-05-2008, 09:18 PM
rapidcossie
rapidcossie's Avatar
two small pieces of metal either side that hold in into the clocks?
these unscrew if I remember right?
Old 12-05-2008, 10:17 PM
AndyPen
AndyPen's Avatar
Takes a bit of a squeeze to release the plastic pins which sit in a groove on the back of the speedo mate. The plastic is usually quite hard and its designed a bit like those childproof lids where you have to squeeze in the right place. Once its off you'll wonder why it was so difficult!
Old 12-05-2008, 10:40 PM
BIG WULL
Fae the Dale
BIG WULL's Avatar
Cheers lads. I'll set about that tomorrow sumtime..
Old 13-05-2008, 05:20 AM
As said you can feel the serated raised bits that you squeeze, just a gentle squeeze is all it takes.
Old 13-05-2008, 12:29 PM
BIG WULL
Fae the Dale
BIG WULL's Avatar
damm i'm an idiot!!
Note for future: squeeze one side only. side with the biggest lug. utherwise your pushing against yourself, the harder you squeeze-the more it grips.
Shit, such a simple task
Old 13-05-2008, 09:58 PM
AndyPen
AndyPen's Avatar
amazing aint it - I think everyone struggles first time around!
RSKim
23
21-02-2006 05:07 PM
ellicoss
17-10-2005 05:53 PM
RSKim
05-09-2005 11:14 PM
RSKim
15
05-08-2005 08:00 AM
Quick Reply: Saffy speedo...
