4x4 Saph Brake Pipes, original Oem
Old 11-03-2008, 08:47 AM
silky16v
Get on That!
silky16v's Avatar
Default 4x4 Saph Brake Pipes, original Oem
does anyone know if you can still get these brakes pipes pre made up from the ford dealership i'm needing the rear pipes on the trailing arms and the pipe that run from front to rear and then the 2 from the T-piece
Old 11-03-2008, 11:18 AM
stevecossy
stevecossy's Avatar
Dont think ya can get em anymore buddy most people just av some made up.
Old 11-03-2008, 12:40 PM
silky16v
Get on That!
silky16v's Avatar
thats what i been told just would like to keep the oem look, but not to worry my mechanic is gonna just take the old 1's off and make new ones that look identical
Old 11-03-2008, 01:29 PM
If you put on HEAT SHRINK, DARK GREEN, then heat it, it will shrink to size and if care is taken not only will it look identical, but will not rot or anything like the oe stuff.
Just put the heat shrink on before doing the last union.
Old 12-03-2008, 05:04 AM
stevecossy
stevecossy's Avatar
As tab Says or ya can just paint them green as on mine, but wont pro last as long as heat shrink.
s1cab
26-07-2018 06:11 PM
c20tbo
17-08-2015 10:19 PM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: 4x4 Saph Brake Pipes, original Oem
