Access to the oil breather box
Old 21-02-2008, 02:30 AM
captiva
captiva's Avatar
Default Access to the oil breather box
I have a LHD Cossie 4x4 and want to know how to remove the oil breather box so I can upgrade it (build one myself). Because it is LHD there is the brake master cylinder and ABS stuff right there so you cannot get your hands in there let alone see it. Don't know where to start.
Old 21-02-2008, 05:00 AM
MARCOSWORTH
MARCOSWORTH's Avatar
Best is to remove the inlet manifold
Old 21-02-2008, 12:51 PM
captiva
captiva's Avatar
Oh that looks complicated, same problem is getting to the bolts with the brake M/C there. But how is the breather held in, is it a push fit with O rings or what
Old 21-02-2008, 01:18 PM
bpspa
bpspa's Avatar
Can you not get at it from underneath as thats how I got mine out (on a RHD 2wd car).
If its the original then its just push fit.
Old 21-02-2008, 03:06 PM
captiva
captiva's Avatar
Thats a possibility but the oil filter is there , thats no big deal , and I think the steering column is too, I guess that is the penalty for having LHD. If it is push fit thats probably why its leaking now I have 27 psi of boost. At the same time I will have to make up a pipe connector that is also push fit with O rings
155lee
27-10-2015 04:55 AM
andrewmctiernan
08-09-2015 03:05 PM
Rizlablue
06-09-2015 09:58 AM
hopper350
04-09-2015 12:53 AM
kevin36
02-09-2015 06:24 PM
Quick Reply: Access to the oil breather box
