RS500 Thermostat
RS500 Thermostat
Hi,
Can anyone tell me if the RS500 thermostat is the same as the 4x4 Sapphire one?
I currently have a 4x4 Sapphire which I'm fitting an RS500 thermostat housing to, I want to use the 82 degree stat that's currently on my 4x4 as it's only 2 months old. Both stats look the same but just want to be sure before I swap them over.
CheeRS
CheeRS
Collar was jammed solid in the housing so got a local machining company to drill and tap a couple of holes in the collar so I can pull it out using two bolts now.
