poly rear bushes
poly rear bushes
the saffs just failed it's mot!!!!!
trailin arm bushes are goosed,wanna fit the poly type,wheres the best place to get them from
and how do you adjust the C/O level????
cheers
cheers
Football Cwazy
if you can afford them, then buy the standard ford bushes for the trailing arms.....the ECU screw adjusts the fuelling over the entire rev range so if you adjust it before MOT, then make sure you put it back to where it was....although it sounds like you need a setup if it's failed
The fuelling does adjust over the whole range but is primarily adjusting the idle circuit.
Any difference it makes is pretty insignificant compared to the airflow at WOT.
It does NOT need adjusting for MOT then putting back if it is ok, it should fly through the MOT at 2-2.5%, and this is the best for nice smooth running as well.
Re: ploy
Originally Posted by rosscoe
cheers 4 the info guys
bud-weis
you reckon the standard bushes are the best then??
bud-weis
Yes mate the standard ones are said to be the best, im sure its because they are one whole bush rather than polly`s ect being 2 parts with the sleeve
I think they need to be machine pressed in aswell, plus theyre a couple of hundred notes to buy if theyre still available
155lee
06-09-2016 11:10 AM
The Enigma
12-09-2015 10:12 PM
