Removal of centre console 4x4 sapphire.
I'm trying to remove the centre console/arm rest, all the screws are out but it won't quite clear the handbrake & the front part won't quite clear the dashboard where the ashtray is. I've removed these plenty of times from my 3dr from memory without any snags Anyone got any ideas, do i have to remove anything extra on the 4x4 ,its almost out but if i force it anymore it will snap
Cheers Simon.
Cheers Simon.
OCD Victim
Put your foot on the brake hard, pull the handbrake lever as far as you can with the pedal pushed. This will give you enough clearance to remove the centre-console. It will still be tight, but should clear okay. I have to do this when I take mine out, and it is a royal nightmare.
More boost Igor!
Originally Posted by steventoon
I found it easier to remove the lower dash
The centre console reaches under the dash too far to bend it without breaking it.
Adam Graham
06-09-2015 06:04 AM
