B&M shifter problems....fouling on tunnel wall???
Ay up people.....just been fitting a B&M short shifter to my 3dr and I seem to be having trouble with it fouling on the top of the tunnel?? Anyone else had this trouble before?? Im using a 909 gearbox mounting but cant see this being the problem as its the same as the stanard mount but with a firmer rubber being used.
Stu.
Stu.
you had the shortshifter and 909mount fitted the same time or was that 909mount there before?
I have the same items under my 3door, i'll have a look at it tonight.
where abouts mate? Im getting a good bit of noise through mine but i think its because its touching the floor because when i push hard down on my gear-stick its just normal and quite
im yet to get out and try to fix it cos i`ve been working, once i have time im gony stip it down to have a look at the floor to see if its touching it
Rinus: Fitted all parts recently...cossie been off road for year and half (its killing me not being able to use it )
Nuttin: This wasnt just touching the tunnel...it was pushing hard against it. Checked the whole underside and found no faults...in the end i had to trim the tunnel shifter hole out to clear and then I used a under bonnet trim peice (the squidgy rubber trim that seals the bulk head panel to the bonnet when its shut) to line the cut metal work and also to provide a neat and tidy seal between gearbox and tunnel whilst allowing movement for engine rock etc. Looks very tidy like that tbh....didnt like taking the tin snips to my 3dr tho
mk3ste
17-10-2021 10:09 AM
