sierra cosworth lamda sensor + closed loop chip
Hello mates!
My cossie has L8 ECU 4x4 non catalystic but with 2wd loom and i bought a chip closed loop,lamda sensor and m18 lamda all these from MSD!
Now anyone knows how can i connect the lamda sensor?
I will need the throttle position sensor?My car already has one but is it the same as MSD?
It will work or i need something else?
My main question is where i have to connect the lamda sensor wires?
Thanks a lot!
Thanks a lot!
Testing the future
the output from the lambda sensor needs to go to pin 2of the ecu
if it is a heated sensor, it will also need power when the engine is running. the 4x4 cosworth with L8 takes the power from the fuel pump relay
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
