ideas
ideas
hello people i have a 4x4 saph, i hit a kerb last year i damaged the strut & track control arm which have now been replaced and the tracking has been done its starting to get tyre wear on the inside and is pulling to the left a bit just wondering if it could be the hub or if you any ideas cheers
Won't be hub, check the distance between front + rear wheels each side.
You may have bent the ROLL BAR ?, would still track up on guages perfectly.
If still trouble got to PROPER alignment centre, or VAG ones as these are awsome, best in country TBH, even test runout of wheels and allow for this in settings, takes a few hours!!
