Spring rates 2wd
Spring rates 2wd
Hello!
Could you tell me the standard spring rates of sapphire 2wd?
The 4wd is stiffer?
And how comaprable the normal sping platform and the coilover spring rates at the rear. (for example 250 lbs/inch coilover means ??? lbs/inch standard spring rate)
The 4wd is stiffer?
2wd cos are 190lb" front, AVO coilovers are 300lb" front.
2wd cos rear 200lb" AVO coilovers, don't know std ford ones for rear.
Confused when you mention comparable platforms ?
On the front the spring rate will be what it is, as it uses the same points as the std spring ie vertical.
At the rear it will be different as it uses a different location point for the spring, there will be a much lower force exerted on the spring by cars weight due to lever effect of effects of the two different mount positions of std springs versus coilovers, have not measured so do not know off hand lever ratio.
SMILER258
28-09-2015 09:04 AM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
