AstonMartin Brembo Brake Setup for 2wd Sapph
C16OSY
Heres your chance to be the 2nd person that i know of to have Aston Martin Brakes on a 2wd Sapph Cossie!
Aston martin DB9 brembo calipers in black with aston martin logo.
These are the rear callipers and pads which are supposed to use 330mm discs. The reason for this is because they fit behind 17 inch wheels.
I opted to use standard Focus RS discs(324mm) because they were largest i could find in a 4 stud pattern. The callipers are near enough brand new, as i got them 1000 miles old, and have only done bout the same again in the cozy.
The discs were brand new at time of fitting so are bout 1k miles old, and not warped or lipped. The pads are standard DB9 brembo pads and are fairly worn but still have loads of life left in em. No brake judder!
The brackets are custom made fron billet steal and are for a 2wd Sapph ONLY unless 3door cossie front hubs/knuckles are the same!
Also included are a set of used 330mm DB9 discs which are 5 stud pattern. I am looking for £500 but would consider reasonable offer.
Fucked On Race Day!!
[QUOTE=turboRS;4064436]for a 2wd Sapph ONLY unless 3door cossie front hubs/knuckles are the same!
QUOTE]
Is this a question or a statement? I don't know if they are the same, i have a three door and could be interested if they would fit it...anyone know?
QUOTE]
its all about the 5 pot
They are fitted to a 2wd saph, or were fitted but if the hubs are the same on a 3dr, they will fit too. I can vouch for the decent stopping power, as well as the eye candy.
C16OSY
[quote=cossie*mad!;4148416]yes they will fit, as the brake lugs are the same even though the hubs are different. cheers
C16OSY
C16OSY
C16OSY
The Enigma
12-09-2015 10:12 PM
