Hi, my clutch has started slipping every now and again so at a guess I'd say the slave cylinder is leaking? Would a Fiesta 1.2 clutch fit? I have one in the garage so would save me money if they are the same.
unless your losing brake fluid then chances are your slave cylinder is fine, more like a worn pressure plate, when some mates did mine they found my flywheel was badly grooved which needed skimming, and I would say a 1.2 clutch wont fit
