Help!!!Ford focus rs mk1 smoke from front of engine
Old 14-07-2015, 11:34 AM
LefkadaRS
LefkadaRS's Avatar
Default Help!!!Ford focus rs mk1 smoke from front of engine
Hello,
I have a problem.i noticed a little bit of smoke coming from the front of the engine when I start it cold. Changed the rocker gasket but it still does the same. What can it be???
Old 14-07-2015, 11:38 AM
haz87
haz87's Avatar
Erm open the bonnet and look when you start it from cold to work out exactly where its coming from....
If its actually "smoke" then its either something burning off, or a massive exhaust blow.
However it could be as harmless as steam due to moisture burning off the manifold etc etc
Old 14-07-2015, 11:45 AM
LefkadaRS
LefkadaRS's Avatar
Thanks..what is an exhaust blow if it is that?
track.focus'd
12-08-2015 05:53 PM
taylora1409
12-08-2015 12:06 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Help!!!Ford focus rs mk1 smoke from front of engine
