Focus rs 2003 front indicator
Old 23-07-2013, 02:30 PM
Perkins_rs
Perkins_rs's Avatar
Default Focus rs 2003 front indicator
Just bought my focus rs (2003) and my front left indicator as gone. Bought the bulb and tool to change it and when went to change in noticed problem.
Right hand side as a plastic broken screw bit which can't undo. And left as metal screw same star end poking out as my tool. What to do??
Old 23-07-2013, 02:31 PM
Perkins_rs
Perkins_rs's Avatar
Want to get new lens for left hand side to as its slightly cracked. Does focus mk 1 front indicator lens fit on focus rs or must it be rs
Old 24-07-2013, 09:31 PM
Smithy23
Smithy23's Avatar
u saying u cant get the right side indicator out due to a broken screw?
Old 07-12-2013, 09:44 PM
flyingfocrs
flyingfocrs's Avatar
I know this is an old thread but if anyone searches it then the answer is - if the plastic bit breaks off the screw the metal bit that's left is a Torx screw head.
An E4 Torx socket will remove the screw.
The screw can still be used even with the plastic bit missing.
Old 08-12-2013, 06:04 PM
minder
minder's Avatar
drill out the broken screw mate and just use a normal stainless screw which is what i have done and the answer to your question about the indicators is NO the rs ones are the only type that will fit your rs normal mk1 ones a to big and a different shape
Old 10-12-2013, 09:41 PM
lowman
lowman's Avatar
thats is not correct
standard focus indicators will fit..as the amber ones are standard focus...and they fit like a glove!
salsheikh
Ford Focus ST Parts for Sale
06-10-2019 07:56 PM
C2 MAK
20-08-2015 09:46 PM
salsheikh
Ford Focus RS Parts for Sale.
20-08-2015 12:22 PM
coozer
Ford Focus Range
15-08-2015 10:26 PM
RIB1122
12-08-2015 08:51 PM
Quick Reply: Focus rs 2003 front indicator
