Heater only blowing cold air help?
Old 09-01-2017, 08:28 PM
lemon81
lemon81's Avatar
Default Heater only blowing cold air help?
Hi i have a mk4 1987 escort 1.6 automatic...
Once the car is up to temp.. half way on the (normal)
it will not blow hot air.. switched to cold blows cold air and switching to
hot will only blow a mild/cold heat....
The car doesn't use any water....
Any advice is greatly appreciated...
Thanks for any reply...
Old 09-01-2017, 09:16 PM
studabear
studabear's Avatar
Are the pipes in and out of the heater matrix hot?
Old 09-01-2017, 10:05 PM
james kiely
james kiely's Avatar
Heater matrix could be blocked or possibly airlocked
Old 10-01-2017, 04:05 PM
lemon81
lemon81's Avatar
Hi After reading the replys I recieved I went out this morning and took the car for a
Drive to get temp up... got back and as advised felt the two pipes leading to
The matrix... one was hot and one was slightly warm...
I got a bit excited and loosened the jubilee clip on the coolant hose....
Wow... Sh#t.... not a good idea... the fuc#ing thing exploded in my face...
I've burnt all my hand on the top.. luckily I still have vision...
I thought it would be hot but it was like steaming molten lava...
After 3 paracetamol I attached a hose pipe to the lower matrix pipe and put
A clear oven glass bowl under the other pipe...
I wish I could attach a picture of what was flushed out...
Big chunks of iron rust and like soil....
Attached all the pipes back on, filled with new water and heater is fixed...
Thanks for the replys I recieved.... you were both 100% correct...
I won't be taking any coolant pipes off again.. fu#k that...!!!
I can only assume that because the matrix was blocked it caused pressure
To build up in the pipe... cheers nick
