Best Actuator on standars S2 engine.
Hi guys.
What is the best actuator to use on a standard S2 engine?
The specs:
Engine is rebuild to original spec. New original Garret turbocharger.
Larger intercooler, K&N panel filter and 2.5" stainless mongoose exhaust.
Hart/diamond/hash ECU, original, not chipped.
I used an old original actuator on the new turbo charger, but it seems the actuator is a bit tired. Starts to open at 0.2 bar (2.9psi)
I only find -18 or -31 actuators beeing sold. But what do these numbers mean? Which should I choose?
Thanks,
The specs:
Thanks,
You sometimes can struggle on a -31 as depending on how well the map sensor works in the ECU they can boost cut at 9psi without a chip in them, and the -31 has a 9lb spring, so you have to run next to no preload.
I've had to chip them before just to prevent them clipping the boost cut.
ossie cossie
13
21-02-2016 06:29 PM
rb5286
02-02-2016 11:38 PM
Bigdaggy123
Ford Focus (All Models)
01-02-2016 03:41 PM
