mfi rs turbo c0
mfi rs turbo c0
% co that I believe necessary, in 18psi boost ?
How I can get more fuel? in mfi
cold start injector?
it has: -31 actuator, chip ecu, kent kams cvh35k, wossner pistons
someone with more knowledge will be along but about 3% Co and with more fuel from the little black box onside of the metering unit. taking it apart and small screw in there will adjust fuelling
You need a wideband lambda sensor set up so you can monitor the air fuel ratio.
half a turn on 1 car will not be the same adjustment on the next car
