For anyone interested in a hydraulic clutch conversion.... NEW TIP! 18.04.10
Old 01-03-2011, 02:20 AM
  #81
wul young
wul young's Avatar
Default pics
Different yet again,works a treat though,Hope it helps.
Old 01-03-2011, 09:47 AM
  #82
muz
Wye Valley Hardcore
muz's Avatar
STOP TEASING US WITH ODD PICTURES, WUL, AND PUT A PROPER THREAD UP!
Old 07-03-2011, 08:00 AM
  #83
wul young
wul young's Avatar
Default lol
Am not teasing m8,its 97% done,im of this week and it will be complete,then for sure i will give you the low down pics etc.thanks.
Old 07-03-2011, 08:44 AM
  #84
muz
Wye Valley Hardcore
muz's Avatar
What shows will it be at, Wul?
Old 08-03-2011, 09:18 PM
  #85
wul young
wul young's Avatar
Default HI
AWrite m8,its race/road as u guessed,so it will be used what it was built for,any track day,thrash etc etc,i will be there,getting abused as was the last 1,lol.this is it for me m8,i will defo never build another,so its ma final attempt on the ford tuning seen,lol.maintained and repaired and rescued many.so yeh this is why its a bit stupid this car,its as far as i can take an old85 shell to the extreme and beyond i would say,so we see what happens a suppose,if its useable then good ifits not then it will be broken as the same as my s1.
Old 13-03-2011, 12:54 AM
  #86
NEIL A
NEIL A's Avatar
Looks like its just about there now Wul
Have you stil got your little white van , think I seen it in Leven the other day.
Old 15-03-2011, 02:57 AM
  #87
wul young
wul young's Avatar
Default awrite m8,longtime no see
cars done its at ava as we speak gettinn mapped,hay ti catch up wi you fir a blether
Old 15-03-2011, 06:28 AM
  #88
NEIL A
NEIL A's Avatar
Im away till the end of the month mate , will give you a shout while im home and bring the new blue oval along.
Old 15-03-2011, 05:35 PM
  #89
series_one_rst
series_one_rst's Avatar
something to look in to in the near future. nice thread.
karlos, what size mc and sc did you end up using in the end?
Old 17-03-2011, 04:34 PM
  #90
Karlos G
Balls Deep!
Karlos G's Avatar
0.625 MC and a Honda Prelude SC I think it was, now on a SportKa box which has a built in SC.
Old 17-03-2011, 05:19 PM
  #91
series_one_rst
thanks matey, will be looking in to this for the s1 as soon as I got the engine mapped up.
Old 20-03-2011, 12:23 PM
  #92
wul young
wul young's Avatar
Default Catch up
Yeh do that for sure m8,no seen u or the motor forever!!!!!!!
Old 07-04-2011, 07:38 PM
  #93
herbcosworth
herbcosworth
herbcosworth's Avatar
could i do this on a t5 cossy box? what slave would you recommend cheers
Old 09-04-2011, 08:42 PM
  #94
Daveysaff
Skint Passionford User
Daveysaff's Avatar
iirc one of the bmw slaves fit on a T5 without too much grief
Old 01-01-2012, 03:13 PM
  #95
DanFraser
DanFraser's Avatar
Sorry for dragging an old thread up, but it is a really good old thread.
I have a 1.6 Fiesta SI, just wondering and basically wanting to confirm what's in my head, that this should be pretty much exactly the same for my Fiesta?
I have a Mondeo master cylinder mod with a factory closed off clutch feed on the reservoir, so this should provide additional fluid correct?
And was that bracket for the slave cylinder made out of the support bracket between a steering rack and servo mount?
Old 02-01-2012, 01:25 PM
  #96
Karlos G
Balls Deep!
Karlos G's Avatar
Yes mate I think that was the support bracket I used and if your reservoir has a clutch feed then yeah should be fine I would think.
Old 15-03-2012, 08:25 PM
  #97
TomPengelly
Kapow!!
TomPengelly's Avatar
I am starting this conversion today. I have removed my clutch pedal (finally!) but it's totally different shape to your one. Mines got a bracket with a captive nut welded inside it. I think il have to get a pedal the same as yours as this will be in the way of the rod
Old 24-03-2012, 02:51 PM
  #98
Pete frst
Pete frst's Avatar
Hi What diameter is the cutting wheel i need for the hole in the bulkhead? cheers..
Old 25-03-2012, 10:26 AM
  #99
Karlos G
Balls Deep!
Karlos G's Avatar
Replied to your PM mate.
I used the biggest one I had and then a die grinder to open it out the rest of the way.
Old 25-03-2012, 12:18 PM
  #100
Pete frst
Pete frst's Avatar
Okay cheers mate,im starting it this week,i hope your's is holding up well....
Old 06-06-2012, 09:44 AM
  #101
Dennis_Wiseman
Dennis_Wiseman's Avatar
Where did you buy this fitting which connects pedal to MC from mate? Any part numbers etc? Cheers
Old 06-06-2012, 09:57 AM
  #102
DanFraser
DanFraser's Avatar
I'd like to add to this further. As this already involves making a bigger hole in the bulkhead I looked into possible options on the pedal end of things. Mondeo MK1 pedal boxes use exactly the same pedal shaft and the master cylinder goes through a hole in roughly the same place as the cable hole in the fiesta, so should be pretty much the same in the escort too.
All I have to do is create the proper hole and then because I have 'zetec yo' I can use a gearbox off a mondeo directly fitted for the actual bona fide hydraulic clutch.
Old 06-06-2012, 11:26 AM
  #103
TomPengelly
Kapow!!
Dennis- i got mine from ebay. Just search for clevis pin with whatever thread you need. Mine is M8
Old 06-06-2012, 02:46 PM
  #104
Dennis_Wiseman
Thanks buddy
Old 07-06-2012, 01:46 PM
  #105
Karlos G
Balls Deep!
Karlos G's Avatar
Dennis I bought mine from the same place I did the MC mate, can't remember where that was now though?! lol
Old 08-06-2012, 06:04 PM
  #106
Dennis_Wiseman
Thanks Karlos, managed to sort it. Arrived this morning from Rally Design. The part number if anyone's interested was G1312, size 5/16. Fits spot on with the mk4 pedal quadrant pin.
http://www.rallydesign.co.uk/product...63o6um4bhm0js4
Old 14-12-2012, 03:16 PM
  #107
kidsRS
"Ill check the stock"
kidsRS's Avatar
can you get a flexible braided pipe from mc to sc, instead of havin a rigid copper pipe?
Old 14-12-2012, 03:38 PM
  #108
anglia105e hinson
anglia105e hinson's Avatar
Yeah look on OPD website for the cheap braided line
Old 14-12-2012, 04:10 PM
  #109
kidsRS
kidsRS's Avatar
also anyone got any pics of the wilwood slave cylinder fitted to bc gearbox, dont think i can fit the prelude 1 like karlos did the 1st time because im still on mfi and room between clutch fork and metering unit is limited im thinking
Old 27-12-2012, 05:27 PM
  #110
basty
basty's Avatar
Would this mod work on LHD cars ?
cheers!
Old 27-12-2012, 06:19 PM
  #111
kidsRS
kidsRS's Avatar
cheers!
Dont see why not
Old 27-12-2012, 06:37 PM
  #112
studabear
studabear's Avatar
cheers!
A good question, my first thought would be that your servo could be in the way of where you would want to mount the clutch master cylinder, anybody got a lhd under bonnet picture?
Old 28-12-2012, 01:13 PM
  #113
Karlos G
Balls Deep!
Karlos G's Avatar
Also my first thought Stu!
Old 30-12-2012, 11:18 AM
  #114
muz
Wye Valley Hardcore
muz's Avatar
So has anyone had any problems with these set ups yet? Such as failing MC's etc?
Old 30-12-2012, 05:34 PM
  #115
Karlos G
Balls Deep!
Karlos G's Avatar
Willwood ones fail (x3) yes, Girling are the ones to use.
Old 30-12-2012, 07:37 PM
  #116
muz
Wye Valley Hardcore
muz's Avatar
Mines an OEM Land Rover one so it should be okay. I might finish mine off tomoz if I can't finish the fusebox.
Old 30-12-2012, 07:50 PM
  #117
crazycage
crazycage's Avatar
ive had loads of them fail , willwood and compbrake but never a girling one . there about £50-60 compared to the otheres @ £15-20 but they work perfect
Old 24-07-2014, 06:02 PM
  #118
HaggisTurbo
HaggisTurbo's Avatar
Can this be fitted with the engine in gearbox in situ or will I need to haul it out to do the master cylinder fitting?
Old 25-07-2014, 04:31 PM
  #119
Karlos G
Balls Deep!
Karlos G's Avatar
I've not done it with the engine in, I imagine if it is possible it's not easy! lol
Old 20-01-2015, 12:55 PM
  #120
malescort
malescort's Avatar
What Girling one did you opt for Karlos, and is that still behaving itself...?
Quick Reply: For anyone interested in a hydraulic clutch conversion.... NEW TIP! 18.04.10
