lamda loop sensor
Old 10-06-2005, 07:40 PM
georgie1
georgie1's Avatar
Default lamda loop sensor
hi everyone where can i get one and how much r they plus can i fix it myself or have i got to go to a garage i live near london
Old 11-06-2005, 11:02 AM
Dave Henshall
Dave Henshall's Avatar
for a big turbo escos...?
here...
http://www.lambdasensor.com/main/ford.htm
you want a 12mm 3 wire titania sensor, the universal one is 70 quid inc delivery and arrived the next day, part number : 11014T12
it doesnt come with the car connector, but does come with proper crims and heatshrink to connect it to the original connector.
Old 11-06-2005, 11:23 AM
georgie1
georgie1's Avatar
ive got a small turbo cossie is that the sensor i need to get through the mot as im going to fit a stainless steel mongoose exhaust without a cat, i was told i need a lambda loop sensor. also where does the sensor go, do i need to do any modifications.
Old 11-06-2005, 11:45 AM
Dave Henshall
i'm not too sure on a snmall turbo, on the t34, the actual probe goes in the turbo housing itself so isn't affected by any aftermarket exhaust.
it will already be lambda controlled, fitting one to acar that didnt have one inthe first place wont do much good as the ecu woun't use it, and besides, a car that was supposed to have a cat WILL NOT pass a mot without one regardless of how well the engine is running. you need to find a friendly mot station that would hahmmmm , wave the emisions probe up the exhaust of a micra on the next ramp along...
Old 11-06-2005, 01:27 PM
georgie1
georgie1's Avatar
hi m8 i know what u mean about not passing a mot with the cat removed but heard people talk about a loop lamda sensor as that make the loop so that the car will pass a mot so that what im after a lamda loop sensor anyone know where i can get one and how much please
Old 12-06-2005, 12:01 PM
Dave Henshall
not heard of one of them mate..
u may be thinking of closed loop fuelling using the labmda probe to control fuelling under certain conditions, but even with this, it wont pass a cat mot with not cat, sorry
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
fordrallycar
30-09-2015 07:57 PM
stevecfrst1
30-09-2015 05:18 AM
Quick Reply: lamda loop sensor
