AP caliper clearance
Old 26-05-2007, 01:29 PM
robbieg
robbieg's Avatar
Default AP caliper clearance
I've just dummy fitted my big brakes and have got minimal clearance between my wheels and six pot calipers it's about 4mm.Do you think this is enough????comments invited
Old 26-05-2007, 01:34 PM
SillyFezzaMk1
Rubber Rhino Crew
SillyFezzaMk1's Avatar
if it turns and there arent any weights on the inside of the wheel then you should be fine.
Dan
Old 26-05-2007, 03:04 PM
RWD_cossie_wil
RWD_cossie_wil's Avatar
what wheels/ brakes you got?
Old 26-05-2007, 04:18 PM
4mm is plenty, if there was this amount of movement of components you would have problems already as something would be shagged.
ps as said, just watch where weights are put but 4mm will clear these as well
Old 26-05-2007, 04:42 PM
robbieg
robbieg's Avatar
Thanks for the replys Didn't think about the weights, have to have a look
RWD cossie will AP CP5555's and 368mm Alcon discs-WOLF ats 18" alloys
Old 26-05-2007, 04:50 PM
rapidcossie
rapidcossie's Avatar
I have almost zero clearence with 5555's under 17's
i can have any weights on them which is a bit of annoying
Old 26-05-2007, 04:53 PM
RWD_cossie_wil
Just put them on and see if they fit , and rotate the wheel slowly a few times by hand first, as Tabatha says, it should be fine, i have just bought 362mm x 32 AP's with a 7040 calliper, and they clear the Rondell 122 18" by about 6mm I think , well GGR assured me they would JUST go on
01-11-2015 06:53 PM
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
IainRS1700T
25-09-2015 06:44 AM
DPDISXR4Ti
Ford Fiesta
21-09-2015 03:51 PM
Quick Reply: AP caliper clearance
