Pro alloy cooler rad etc
Looks like it just bolts to the top of the rad mate, in the position where the intercooler is at present...
I'm going to be doing exactly the same over the next couple of weeks, and have taken it all out already! - I guess you've got the bolts / rubber busing that you need from ford to fit the cooler and rad together on the alloy Pro-Alloy bracket?
you may fine you need to extend the mounting holes on the pro-alloy fans slightly too - i'm using a normal ford rad, with pro alloy fans, and found the mounting holes for the fan frame are slightly out - not by much, but a bit!
Ive got the Pro-ally Rad, Intercooler and Turbo cooler fitted on mine.
Fits all nice and snug. Had to mod the holes a little bit on the Intercooler to make it fit nicely. I would strongly advise you ditch the standard fan setup and buy pro-alloys thiner ones, as the standard fan setup would make it extremely tight and close to the belts.
The turbo cooler fits lovely, had to make some holes in the top of the rad, and knock up some bolts to hold it in place. Ive got my turbo cooler areoquiped up as well so looks pukka.
