part no
Old 19-01-2007, 05:24 PM
THE RADMAN
THE RADMAN's Avatar
Default part no
anyone got the part no for the little alloy washers that go on the banjo bolt of the turbo for the water feed? big t by the way
Old 19-01-2007, 06:43 PM
DENNIS
DENNIS's Avatar
i dont use ford ones they leak !! lol
i think my ones are vauxhall V6 oil cooler ones ???
they are doughty seals, you can get them from most places..
i will check and get the gm number if you like..
Old 19-01-2007, 09:48 PM
THE RADMAN
THE RADMAN's Avatar
never thought about that, are doughty ones ok with the heat though ? dont want it melting the rubber seals maybe copper ones would be ok?
Old 20-01-2007, 12:22 PM
DENNIS
DENNIS's Avatar
i use these because of the heat !! i run anti lag and the seals are rubber / copper...
not had any problems with them.......
the ford ones used to drip a little on the exhaust when very hot and cause a nasty burning antifreeze smell...
gambo08
04-02-2016 10:49 PM
07-10-2015 12:56 PM
01-10-2015 02:00 PM
fordrallycar
30-09-2015 07:57 PM
Fordmad!
29-09-2015 07:03 PM
Quick Reply: part no
