fiesta RST tuning help
Old 12-02-2016, 04:50 AM
bluntys1rsturbo
Boost addict
bluntys1rsturbo's Avatar
Default fiesta RST tuning help
hi everyone im hoping some of you good people can help me with a few matters, i had a deal fall through on a frst i was meant to be buying but have struck another deal on a nice little near standard engine wise example.
the car im buying is running some sort of hybrid turbo but will be in need of rebuild as the seals have gone, this is not a problem as it will be sent to wilky for some of his magic and hopefully a top spec hybrid
my questions are as follows
what fmic can i go for which will be good for around 18psi boost and wont require butchering the front of the car as i hate that look?
is it worth getting one of the airtec turbo coolers or are they just a gimmick?
also what cam will work best with a t25 hybrid iv seen the kent 31 and 34 camshafts and also a bayjoo special?
id imagine i need an uprated fuel pump and possibly spark plugs if so which ones are best to go for?
i have decided that the car will be going to msd for one of there stage 3 conversions once i have the fmic and cam in place
any help/pointers would be greatly appreciated
Old 12-02-2016, 06:22 AM
JK12
JK12's Avatar
i used Auto specialist one - Didn't want to cut mine either!
Old 12-02-2016, 08:55 AM
bluntys1rsturbo
Boost addict
Cheers for that pal was it a stage 1 or 2 fmic you went for? Also what boost are you running and how are the act since fitting
Old 12-02-2016, 09:17 AM
JK12
JK12's Avatar
Think stage 1 as the stage 2 needs to be cut when you read it. This with the ally rad keeps her nice and cool. I also have the turbo cooler too.
Im running a bar, but on my updated T2 and management so different set up to you completely!
bluntys1rsturbo (12-02-2016)
Old 12-02-2016, 03:46 PM
bluntys1rsturbo
Boost addict
thats great to know fella i think ill get one of the turbo coolers also and see what nick the rad is in before i make a decision on that, thanks again
JK12 (12-02-2016)
Old 13-02-2016, 04:06 AM
bluntys1rsturbo
Boost addict
can anyone shed any light on the other matters eg cam/fuel pump/plugs etc and also is headwork worth doing at this stage or not
Old 15-02-2016, 06:26 AM
JK12
JK12's Avatar
I use the MSD FRST updated fuel pump - Runs fine
bluntys1rsturbo (16-02-2016)
The Youth.
27
25-02-2018 06:25 PM
BAI7200
22-02-2016 08:47 PM
nixon_2wd
31-01-2016 06:41 PM
RSNUT!
18-01-2016 06:19 PM
Indyrs
13
15-01-2016 08:44 AM
Quick Reply: fiesta RST tuning help
