Kenwood W5541U
Old 19-06-2015, 12:34 PM
Moderator
STeve's Avatar
Default Kenwood W5541U
This is a great stereo with a single Sub pre out but fully adjustable from the head unit, bright blue illumination with USB/jack plug sockets, very good sound quality and used by me for the past year and is fault free, comes with cage and wiring
£40 + p&p
Key Features
CD Player with MP3/WMA decoder built-in
Front Aux input (Mini-jack)to connect portable audio players
Front USB
Blue Illumination
Supreme technology
External media control capability
iPod digital connection, bluetooth (handsfree + audio) ready
Rear- or Sub-preout with 2.5V output level
4 x 50W max output power
General Features
DIN Size 1 DIN
Detachable Faceplate Yes
Protection Case For Faceplate Yes, Soft Case
Faceplate Mechanism Full Detachable Faceplate
Key Illumination Blue
Rotary Encoder & Control Knob Yes
Operation mode 4-Directions + Push
Attenuator with Smooth Volume Return Yes
Touch Sensor Tone Yes
Optional IR remote controller Yes
Digital Clock (24H) Yes
All-off Select (20/40/60 minutes) Yes
Built-in Connector Molex 16 pin
ISO connector Yes
Optional Bluetooth unit Yes, KCA-BT200
Display Features
Display Type Fluorescent (FL) Tube Display
Display Layout 14 segments x 13 Characters
Dimmer Control 2 steps - Automatic
Display Off Mode Yes
Demo Mode Yes
Special Character Display No
Cosmetics features
Front/edge Shiny Black
Dress plate Silver
Volume & operation knob or wheel Chrome Plated
Preset key finish Black Injection
Escutcheon finish Black Injection
Triangle Illumination Red
Volume & operation knob illumination Blue
Key illumination Blue
Tuner Features
Radio Data System Yes
Radio Text Yes
K3I - Clean Reception Tuner Yes
FM Reception Yes
AM (MW/LW) Reception Yes
Presets 24 Presets (18FM / 3LW / 3MW)
Automatic Memory Entry (AME) Yes
Up/Down Seek Tuning Yes
Tuning mode (Auto1 / Auto2 / Manual) Yes
FM Stereo / Mono Selector Yes
Program Type Function (PTY) Yes
Enhanced Other Networks Function (EON) Yes
CD Features
CD-R/RW Compatible Yes
MP3 Playback with ID3 Tag Display Yes
WMA (Windows Media Audio) Playback Yes
AAC (Advanced Audio Coding) Playback Yes
Multi-session Disc Playback Yes
CD Text Support Yes
Supreme Yes
D.A.C. processing 24 bit
Random Function (Track) Yes
Repeat Function (Track/Disc) Yes
Scan Function (Track/Disc) Yes
USB Features
USB terminal Yes, Front (built-in)
USB Type USB1.1 / USB 2.0
USB extension cable supplied no
MP3 playback with ID3 Tag Display Yes
WMA (Windows Media File) playback Yes
AAC (Advanced Audio Codec) playback Yes
iPod Features
Made for iPod Yes
USB Direct Control with optional cable KCA-iP100
Music playback Yes
Music library search Yes
Works with iPod Classic *
Works with iPod Video * 5th/6th generation
Works with iPod Touch * 1st/2nd Gen
Works with iPod Nano * 1st/2nd/3rd/4th Gen
Battery charge + power control Yes
* Always update to latest Apple firmware
External Media Control Features
Dual Changer Control (CH1, CH2 & AUX) Yes
CD Text Ready with Compatible KENWOOD Units Yes
Disc & Track Repeat Yes
Disc & Track Scan Yes
Disc & Track Random Play Yes
Direct Access Yes
Bluetooth Handsfree Yes
Bluetooth Audio Streaming Yes
iPod Control with KCA-iP500 Yes
Audio Features
Maximum Output Power 50W x 4
Auxiliary input Yes, in front panel
Auxiliary Type Mini-jack
Pre-out 1 RCA
Pre-out Output Level 2.5V
Preout Rear / Subwoofer Switchable Yes
Subwoofer Reference Level Adj. Yes
Dual-Zone Source & Volume Control Yes
Dual-Zone (FRONT / REAR Switchable) Yes
Source Tone Control & Memory Bass / Mid / Treble
Balance/Fader/Loudness Control Yes
Att.(-20dB) with smooth Volume Return Yes
System Q (Preset Sound Control) Yes
System E's (Built-in HPF& LPF) Yes
Connectivity
Changer Control (5L-Bus) Yes
External Option Control (5L-Bus) Yes
AUX input (5L-Bus) Yes
iPod I/F Control (5L-Bus) Yes
Bluetooth Control (5L-Bus) Yes
PS Amplifier Control System (5L-Bus) No
iPod Digital Connection (1 Wire) Yes
OEM Wired Remote Control Yes
Power Control (P.CON) wire Yes
2-way (Tel/Navi) mute wire Yes
Dimmer control wire Yes
Tuner Specifications
FM Frequency Range 87.5MHz ~ 108MHz
FM Frequency Step 50kHz
FM Usable Sensitivity 0.7μV/75ohm (S/N 26dB)
FM Quieting Sensitivity 1.6μV/75ohm (S/N 46dB)
FM Frequency Response 30Hz ~ 15kHz (± 3dB)
FM Selectivity(DIN) over 80dB (±400kHz)
FM Stereo Separation (1kHz) 35dB
MW Frequency Range 531kHz ~ 1611kHz (9kHz step)
MW Frequency step 9kHz
MW Usable Sensitivity 25μV
LW Frequency Range 153kHz ~ 281kHz (9kHz step)
LW Usable Sensitivity 45μV
CD Specifications
Laser Diode GaAIAs
Digital Filter(D/A) 8 Times Over Sampling
Digital/Analogue Converter 24 Bit
Spindle Speed 500 ~ 200rpm (CLV: 1 times)
Wow & Flutter Below Measurable Limit
Frequency Response 10Hz ~ 20kHz (±1dB)
Total Harmonic Distortion 0.008% (1kHz)
Signal to Noise Ratio 105dB (1kHz)
Dynamic Range 93dB
MP3 Decoder Compliant with MPEG-1/2 Audio Layer-3
WMA Decoder Compliant with Windows Media Audio
AAC Decoder AAC-LC".m4a" Files
USB Specifications
USB Version compatibility 1.1 / 2.0
File System FAT 16/32
Maximum Supply current 500mA
MP3 Decode Compliant with MPEG-1/2 Audio Layer-3
WMA Decode Compliant with Windows Media Audio
AAC Decode AAC-LC "m4a" Files
Audio Specifications
Maximum Power 50W x 4
Output Power (DIN45324,+B=14.4v) 30W x 4
Preout Level 2500mV / 10kOhm,
Preout Impedance ≤ 600Ohm
Speaker Impedance 4Ohm ~ 8Ohm
AUX Frequency Response 20Hz ~ 20kHz (±1dB)
AUX Maximum Input Voltage 1200mV
AUX Input Impedance 100kOhm
Bass Tone Control 100Hz ±8dB
Middle Tone Control 1kHz ±8dB
Treble Tone Control 10kHz ±8dB
General Specifications
Operating voltage 14.4V (11 ~ 16V Allowable)
Maximum Current Consumption 10A
Dimensions (WxHxD) 182 x 53 x 155mm
Weight 1400gr
Instruction Manuals ENG/FRE/GER/DUT/ITA/SPA/POR
STeve is offline
Old 21-06-2015, 04:12 PM
Moderator
STeve's Avatar
£40 plus postage or can bring to passionford watford meet or uxbridge autoshow or ford fair if pre paid for
STeve is offline
Old 26-06-2015, 05:21 AM
Moderator
STeve's Avatar
Sold sold sold
STeve is offline
Lee R
Alloy wheels and ICE for sale
18-08-2005 08:01 PM
CozzyBrom
05-06-2005 08:58 PM
dave green
02-07-2004 07:56 PM
CRABBY
29-03-2004 09:27 PM
Quick Reply: Kenwood W5541U
