BBS 18" split rims & Centrelock hubs
Old 25-02-2009, 08:32 AM
Touring Car Spares
Touring Car Spares's Avatar
Default BBS 18" split rims & Centrelock hubs
I have an in complete set of rims , 1 x inner and x outer required to make up a set , you'd probably want to change the size anyway to be fair as theyre probably a bit big for most at 11.5" and 12.5" wide.
These are centrelock centres with a drive peg pattern of 5 x 120mm pcd on the hubside , this pattern is quite common for BMW , audi and few others .
Ive also got a set of Centrelock Hubs , originally mosler and unusual in that theyre a bolt on as opposed to a "complete spindle " , this will allow the usual bolts /studs to act as locators and drive pegs too .
Unusual , but may be of some use to someone brave enough to try them out . £2000 plus the vat etc...
If you want a full conversion i have 4 complete corners too !!!
Sierrasideways
08-10-2015 06:37 PM
07-10-2015 12:56 PM
fordrallycar
30-09-2015 07:57 PM
IainRS1700T
25-09-2015 06:44 AM
jc1989rs
05-09-2015 08:09 PM
Quick Reply: BBS 18" split rims & Centrelock hubs
