granada mk3 alloy wheels
Hi everyone, I have a question about my Granada MK 3. I am looking to put some alloys on but have no idea what other make of car has the same wheel configuration (if you know what I mean??) my Granada is 5 stud, so 5x112 is what I would be looking for? is there anywhere on the board that has a post about different wheels for different cars? Or can anyone help with any info...
Thanks in advance. |
Originally Posted by Excalibor
(Post 6691906)
As Costina has said you can fit anything that has the 5x112 stud pattern.
It's just the center bore you need to watch. The mk3 Granada's is 63.4 (but please double check this against another reference) Any wheels that have a bigger center bore will require the correct spigot ring to make up the difference, any wheels with a smaller center bore will need machining. You could also opt for some hub-centric wheel adapters so you could go from 5x112 to..., well, skys the limit, or rather the wallet. |
© 2024 MH Sub I, LLC dba Internet Brands
