injector removal
Old Jan 10, 2006 | 10:41 PM
mk1nurburg's Avatar
mk1nurburg
Default injector removal
does anyone know how to take the fuel rail and injectors out of the inlet for a 2.0ltr pinto? or less specifically does anyone know how to remove injectors in general? might be a similar fitment to these... just dont want to force them and damage the injectors. thanks.
Old Jan 11, 2006 | 08:34 PM
vyper developments's Avatar
vyper developments
Hi
the injectors are usually held in the fuel rail by some metal clips which slide out, the rubber "O" rings at either end of the injectors are a good tight fit and will require a fair old wiggle and a tug to get them out. when refitting smear a small amount of grease on the "O" rings to ease them in.
Mike.
Old Jan 12, 2006 | 08:26 PM
xr-stu's Avatar
xr-stu
ive changed injectors in a zetec fuel rail a few times and if theyre anything like, carefully use a small flat head screwdriver to get in and lever them out bit by bit. when refitting, put them in place and carefully use a vice to press them back into the fuel rail. CAREFULLY though! dont over do it!
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
cossie330
Oct 7, 2015 08:22 PM
Fudgey
Sep 17, 2015 01:06 PM
cos elle
Sep 16, 2015 06:37 PM
