Anti lag..... Whats the score
I'm thinking of going for some mild anti lag on my 4x4 stage 3 saph.
What exactly do i need, were can i get it and how much, also i will need a re map right?
Any help appreciated
you need to use a p8 ecu with a anti lag board i go mine frone engine advantages cost about Ł400
Also you need to get your ids valve and throttle body modified that costs about Ł100 but you looses your cold start fast idle so they run a bit shit when cold
anyone know how to wire it up ??
i have a p8 loom with als on it, also have the inlet and throtle body from the car it came from, so i just need to find out where to put this wire with als on it
1 Post
under teh bonnet the wiring remains the sme. the only additional wiring in teh car is a swicth input to one of the ecu pins that is usually not wired, this when grounded throug the switch , makes teh als active,
1 Post
if setup correctly, the car will idle making almost full boost, so the moment u touch the throttkle you have full boost without having to wait for the turbo to build up to speed and pressure. on cossies though its fairly primitive and retards the ignition lots , throws lots of fuel in and its actually fuelling and sparknig when the exhasut valves are open casuing the turbo to get hot,
without a proper turbo with the correct shaft etc, u will fook a good turbo in no time at all and overheat it. u really need a temp probe in teh exhaust to monitor the temps. its used on rally cars, but i myself was going to have it donw, but speaking to people who have had it, they find for normal road driving it doesnt make any real difference, and is only really any good for showing off and scaring grannies as it goes bang bang
Its only a mild set up only makes about 5 psi of boost i had a standard turbo and ut lasted for over a year. Its not as if anti lag is switched on all the time just when i want to have a bit of fun
It does make a differance can spin all 4 wheels from start ( not good for gearbox but it aint broke yet) and pulls better through gear change.
Engine advantages sell the boards and chip ( but your best of getting it mapped by them if your engine is modified) and if you send youf throttle body and idle valve they nod it for you and send it back in about 1/2 weeks
has any one got some pic,s of a mod trottle body so that i get the idear of how its dun
thanks graham
thanks graham
