Ignition management.
Old Oct 6, 2005 | 11:07 PM
Pornstarr's Avatar
Pornstarr
Default Ignition management.
I'm looking to use a programmable DIS system on my Mk2 Fiesta build, and I'm looking around at whats available to run the ignition. The problem I'm having is finding positive (or negative) comments either way on the different brands.
I dont suppose anyone on here could help with any knowledge they might have on the situation.
At the minute, I'm keenly eyeing up an Emerald MD3k jobbie.
But, what else is available?
(p.s. it'll be a 2.0 ZVH, using the Zetec fly + CPS, and a Throttle pot on a set of 45's/R1 Carbs).
Cheers,
Pornstarr
Old Oct 7, 2005 | 12:27 PM
sailorbob's Avatar
sailorbob
Always been impressed with Dave Walkers' (Emerald) write ups. But overall I think the key to getting things right end up being more down to the guy who maps the system rather than the system itself.
Old Oct 8, 2005 | 08:50 AM
JesseT's Avatar
JesseT
Megasquirt can use the 36-1 flywheel, ford CPS and EDIS wasted spark module directly.
http://www.bgsoflex.com/megasquirt.html
http://megasquirt.sourceforge.net/extra/
Old Oct 8, 2005 | 05:46 PM
Pornstarr's Avatar
Pornstarr
I've had a look at megajolt, but it's a bit amature, and unsightly.
The Emerald (or OMEX) ECU has coil drivers etc built in, so no need for the EDIS. They're also far more mappable by all accounts.
Old Oct 21, 2005 | 11:12 PM
Gotech Racing's Avatar
Gotech Racing
Have a look at Gotech MFI-STD.
Has been fitted and tested in Performance Ford Mag (S2 RS turbo)
Check out the thread here!
https://passionford.com/forum/viewtopic.php?t=146861
Very well priced, can run coil packs direct from the ecu - no amplifiers needed!
Launch control
Data logging
And more
Daniel Howard
17
Sep 26, 2015 12:39 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
beller
Sep 21, 2015 04:13 AM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
