PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   Technical help Q & A (https://passionford.com/forum/technical-help-q-and-a-14/)
-   -   Smokin Cossie (there's a new one) (https://passionford.com/forum/technical-help-q-and-a/62030-smokin-cossie-theres-a-new-one.html)
gaz3678 Jul 1, 2005 01:17 PM
Got a 2wd cossie, new engine- new 200 block, long studded, ported head, new t34 with .48 exhaust. Running stg 3 (only 20lb/ft as i'm waiting to get it mapped), 500 ic and a pace breather/cache tank. :top:
The engine is vented in 3 places, below the turbo at the base of the block, cam cover and just after the metal kidney/ flame trap. The return to the inlet manifold has been removed aswell.
When i'm running along the motorway, and i totally close the throttle and then bring the rev's down (by braking for example), i reopen the throttle i get a large puff of white looking smoke. If i drop the car into neutral, slow down and then select the right gear i don't seem to get the smoke.
The boost gauge (when the throttle is closed reads - 12 to 13 lb/ft)
I'm not using coolant but i am using oil. i'm currently running 10w40 comma xt2000. Possibility of oil thinning out when it gets up to temperature??
Any suggestions???????? I feel like i'm :wall:
Cosworth-PT Jul 2, 2005 04:06 AM
I would use 10w60 (castrol rs or tws motorsport) or mobil 1 motorsport, but hear what experts have to say. :)
cossied Jul 2, 2005 09:04 AM
smoke
did you renew the valve guides
gaz3678 Jul 2, 2005 03:56 PM
Cheers for the replys chaps.
The guides haven't been changed - to my knowledge, but it was a secondhand head. If it were the guides, it would smoke more often than that- surely?? :wall:
stevieel Jul 3, 2005 08:40 PM
i had exactly the same problem, it was my valve oil seals(well shot they were, found some pieces of them in the sump)
Good luck
Ste
© 2026 MH Sub I, LLC dba Internet Brands
