Co adjust mk4 efi escort
Old Sep 19, 2018 | 12:31 AM
f40cab's Avatar
f40cab
Default Co adjust mk4 efi escort
Hi after some help adjusting co potentiometer. Should it just adjust with car running or do you need to plug in to a diagnostics machine. Is there a set way to set it up. Thanks
Old Sep 19, 2018 | 05:18 AM
haz87's Avatar
haz87
Engine running, using gas analyser to monitor/set correctly
Old Sep 19, 2018 | 08:03 AM
f40cab's Avatar
f40cab
So can you just adjust it with engine idling. I've got a gas analyser to check reading.
Old Sep 19, 2018 | 08:22 AM
haz87's Avatar
haz87
You start there.
Ideally you'd then want to go for a drive with an AFR gauge hooked up to ensure all is well throughout the driving range
cossiecrew
27
Aug 18, 2014 10:10 PM
Skotie jay
16
Sep 5, 2010 09:45 AM
andyc23
Feb 29, 2008 04:50 AM
Windle
14
May 3, 2007 05:34 PM
