Ford sierra rear hub identification help please?
Hi,
could anyone please help me identify which model sierra these are from. From the info I've managed to find I think it's the caliper mounting lug distance that differs on the various models. Thanks Barry https://cimg0.ibsrv.net/gimg/passion...4e43022214.jpg https://cimg1.ibsrv.net/gimg/passion...1a2cadbffb.jpg https://cimg2.ibsrv.net/gimg/passion...01a8b0b4ea.jpg 50 mm.<br/> |
I know the Sierra 4x4 rears I had on my 205 were different to the 4x4 Cossie ones.
Anembo stock Billet Rears with bearings - I THINK they are made by MK. |
Without checking some I have at home later the high spec normal Sierras use a 257mm disc and the cossie uses a 273mm disc in either solid or vented.
They do look like cossie ones. But I can check later for defenate. |
Hi, thanks for the replies. I thought they may be cosworth but all the pictures I could find of cosworth hubs had a strengthening piece between the caliper mounts that these haven't.
Thanks Barry |
Sorry to say Barry they are not cossie hubs, and as you first thought they do have more meat between the mounting holes.
Cossie measure up at 62mm Paul |
Hi, thank you for taking the time to measure yours. So not cosworth or standard sierra disc brake. Narrowing it down now????
It will be the std disc set up 257mm disc.
© 2024 MH Sub I, LLC dba Internet Brands
