MK1 Focus ST170 Clutch Advice - PassionFord - Ford Focus, Escort & RS Forum Discussion
Old 16-05-2018, 04:42 AM   #1
rsg26
Default MK1 Focus ST170 Clutch Advice
Hey guys
I have recently bought a 2004 Ford Focus ST170 that is in need of a new clutch and flywheel. Its an 05/2004 Model. After some research I have found a LUK 07175 clutch kit which includes the flywheel. These seem to be a lot cheaper than other options. My issue is it generally states these are for 03/2004 and older models.
I have found a Sach clutch kit but it double the price. The specs seems to be identical:
https://www.ebay.com/itm/2002-2004-F...IAAOSwIhtanKY0
https://www.ebay.com/itm/NEW-Clutch-...5.c10#viTabs_0
Does anyone know if I can use the LUK 07175 on my 05/2004 Model, and what the differences might be with the clutch?
Any help hugely appreciated.
rsg26 is offline   Reply With Quote
Old 16-05-2018, 08:47 AM   #2
big_wasa
They changed the diameter of the clutch and fly' and upped it from 230mm to 240mm.
As a full package they are interchangeable. If the car is a keeper look at the ttv/ helix setup. If your tuning it, the same.
big_wasa is online now   Reply With Quote
Old 16-05-2018, 09:43 AM   #3
costina
Live long and prosper!!
costina's Avatar
As above I just fitted a luk clutch 240mm to mine cost 446 on eBay.
Its a pig of a job and you will need a 22mm clutch alignment tool and a fitting tool to compress pressure plate before tighening...
IF YOU DON'T YOU WILL HAVE NO CLUTCH.....
Spray all suspension pinch bolts with WD as they usually seize along with the drive shaft splines.
Good luck or better still pay a garage to do it I would next time and I am in the trade....
costina is online now   Reply With Quote
Old 16-05-2018, 01:48 PM   #4
rsg26
Default What model clutch was it?
What year is your st170? Which luk clutch did you get?
Old 16-05-2018, 02:40 PM   #5
costina
costina's Avatar
Ebay seller Parts2clear.
The Following User Says Thank You to costina For This Useful Post:
1-PD (17-05-2018)
Parts advice MK1 Focus ST170 rsg26 Technical help Q & A 1 24-04-2018 06:11 AM
MK1 Focus RS & Focus ST170 rear caliper carriers? philg12 General Car Related Discussion. 1 28-08-2014 06:30 PM
st170 clutch advice please ricky_2006 General Car Related Discussion. 2 21-09-2010 04:55 PM
ST170 Clutch & Flywheel advice Rob Anderson Ford Focus RS 6 15-04-2010 07:46 PM
Will ford focus st170 alloys fit my focus mk1 2003 1.6 zetec? gazloveslou General Car Related Discussion. 2 21-02-2009 08:57 PM
Tags
clutch, st170
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
