Does my car have a WET BELT?
No more Alfa's for me...
Hi all,
REF: 2008/58 Ford Focus 1.8TDi Zetec. Currently has 89k.
Cambelt is due around 100k mark.
I'm trying to get some costs for an early cambelt change (it's also due a light service; had a full one last year).
I'm getting differences of opinion from various garages and EVEN from Ford Service / Parts as to whether it DOES or DOES NOT have a WET BELT as well as a timing belt/chain.
WTF is a wet belt and has my car deffo got one or not?
What's THE best way to find out? lift the lid and look?
Confused Dot Com and then some!!!
IF it does have a wet belt, does it need changing, and when?
Thanks in advance as always guys...
kiteboystu (06-02-2018)
By cover do you mean the big plastic one (which my engine is missing) or the actual metal casing of the engine itself?
No need to remove the timing cover !
If you remove the tensioner and the end of the plunger is flat, Then you have belt . If when removed it has a slight dome it's a chain. If your unlucky enough to have a belt, get it changed asap ! My daughters Galaxy distroyed it's self recently. I've since rebuilt a second engine but with the a timing chain conversion. Do a search on YouTube theirs a guy on there tells you what what. The adapted boss you need is actully a Ford part ! The boss and aftermarket chain is about 300 quid plus fitting .
Hope this helps
Adder
Hope this helps
Adder
Hope this helps
Adder
Hope this helps
Adder
I guess I need to decide if it's worth throwing money at it or buy a newer mota.
If it's NOT got a wet belt I'm looking at around Ł450 for a Service, Cambelt and Water Pump (best price I've got, and I asked several garages).
If it HAS got a wet belt it's more like Ł750 (including the wet belt chain conversion kit).
Wet belt is due at 125k, Cambelt is due at 100k - car has done 89k. I know they can both go early though.
I need to have a think...
Thats the vid I was talking about. Tbh a mate of mine has the 1.8 in a focus and its nudging 250k And he's not shy with it ethier ! I think if you have the chain which is a duplex jobbie I rekon you'll be ok if not the Ford numbers are:
Cassette - F1198056
Tensioner - F 1105977
Hub - F1508244
Bolts - F1352698
This little lot is a bit dare but you motor factors will be able to get an ultra parts kit with all in including the Ford boss . The difference is that the Ford cassette come built up were the ultra parts one you to put together youself. Anyway good luck with it
Adder
Cassette - F1198056
Hub - F1508244
Bolts - F1352698
Adder
Cassette - F1198056
Hub - F1508244
Bolts - F1352698
Adder
Cassette - F1198056
Hub - F1508244
Bolts - F1352698
Adder
Normally it's the upper belt that gets done and the bottom one is forgotten about. Even if it's a chain it still needs changing at the same interval. I had both done on my old Mondeo, it was a ciuple of years ago now but i think the cost was getting on for a grand!
Is the service interval not stated as 150k for these ??
Ford really must have been drinking some serious shit when they came up with that design and service interval !
Lots of them will spill their guts before 100k.
It is rarely the belts that fail, but the tensioners. It is all to do with sales figures. People are drawn in by long service intervals which makes the car more appealing to someone doing a lot of miles, however by the time that a lack of servicing is causing problems, the warranty is long gone so the manufacturers don't need to care.
Quick Update
Firstly, it has NO Wet Belt.
The cars all sorted - Service and Cambelt done.
Very interestingly though, the mechanic said he was 'surprised' (but in a good way) when he lifted the bonnet to reveal what he described as 'an earlier derivative of the escort engine'?! which they made up to around 2003 for Escort Cars and Vans.
This mean't it was a lot simpler and easier to work on apparently AND that it was Ł100 cheaper.
Ł350 for the Service and Cambelt change.
So there we have it.
Pays to shop around
One garage insisted it DID have a Wet Belt and quoted me Ł850!
Thanks all for your input.
I hope this thread helps anyone else out with the same mota as me.
Pays to shop around
lee2cossies
47
21-11-2014 07:42 PM
stu21t
30-12-2010 05:10 PM
