Fiesta RS turbo Co Pot resistance
Old 18-01-2018, 10:32 AM
90_spec
Escort RS Turbo
90_spec's Avatar
Talking Fiesta RS turbo Co Pot resistance
Hi Everyone,
Would anyone be willing to measure the resistance across their Co Pot of a fiesta RS turbo and let me know the readings?
PIN 1 to 2
PIN 1 to 3
PIN 2 to 3
Would be really useful if possible,
Many thanks
Rich
Old 22-01-2018, 04:04 PM
davidfox280585
davidfox280585's Avatar
hi rich,
ive just had a job on where the car had underlying issues, iirc i checked my mates and come back to a measurement of 3.24 dont ask me what setting on the multimeter but you will get it im sure
my issue turned out to be a fuel pressure reg even though it had the anti tamper cap still as factory the car was not running the correct 3 bar fuel pressure
Old 22-01-2018, 11:47 PM
Rich87
Rich87's Avatar
If i remember and you still need them I'll do it Wednesday night when I'm in my unit
Old 23-01-2018, 08:00 AM
90_spec
Escort RS Turbo
90_spec's Avatar
HI David, thanks for that, ive read somewhere that its a 5Kohm pot, so the 3.24 would point towards Kohm, but weather t hat is between single and GND or Signal and V-Ref will tell us the output voltage and therefore the setting,
Rich, that would be really useful if you could,
Thanks
Rich
Old 23-01-2018, 11:55 AM
davidfox280585
Thanks
Rich
i am pretty sur ei could only get one reading regardless when i set this, i had the same issue and went to a friends who had a unmolested fiesta turbo and metered his and set mine exact
Old 23-01-2018, 02:04 PM
90_spec
Escort RS Turbo
90_spec's Avatar
OK, so I was waiting for one from ebay to come,
The Co Pot is a 5.82K Pot and this reads across PIN 1 and PIN 3
PIN 1 to PIN 2 = 4.4K and PIN 2 to PIN 3 = 1.63K
4.4 + 1.63 = 6.3K so I can only assume there is an offset resistance in the Signal output or wiper leg of the Pot of about 200 to 300 Ohms
PIN 1 = GND
PIN 2 = Signal to ECU
PIN 3 = 5V Supply (V-Ref)
Would anyone else care to share their values?, mine has the cap on but clearly been tampered with.
Cossie Sean
25-01-2006 12:04 PM
Kelv
Ford Escort RS Cosworth
09-01-2006 07:40 PM
john banks
01-04-2005 06:04 AM
Garage19
28-09-2004 11:23 AM
Quick Reply: Fiesta RS turbo Co Pot resistance
