Ford Focus 2.0 tdci Auxillary Fan Belt 2010
Damn Cars
Got a belt that seems too loose even though it appears to be the same length as the one that's come off.
The new belt is a Gates 6PK1218
There looks to be only 4 pulleys for the belt to go around but I can't even find a diagram on Google, the only ones on there have 6 or 7 pulleys, I can only assume this is the wrong belt, am I right in thinking this?
Damn Cars
I didn't as the belt snapped but it looks pretty obvious the crank shaft, water pump (I think) and alternator all have the grooves and the tensioner doesn't, 2 are at the bottom, the other at the top and the tensioner just below the top but I can't even find the same setup anywhere on Google.
Crankshaft lower left, aircon to the right of it, alternator above aircon all should have ribbed pulleys. The tensioner should be smooth above the crankshaft pulley so it should only go on one way, you might have the wrong belt if it won't go on.
Damn Cars
Where can I find a part number for the belt to confirm and where can I find a diagram for the pulleys and belt as at the moment as far as I'm concerned my engine does not exist.
Damn Cars
Yes that's correct, I will have to check where I got the belt even though a thin part of the original belt survived and is the same length as the new one.
Damn Cars
Yes it has air con, the only diagrams I can find have 6 or 7 pulleys but obviously it's not rocket science as to which way it's routes around mine, the shop even took my reg number for the belt part number.
Damn Cars
I've just figured it out in my head, dull as fuck sometimes.
I think I was putting the belt around the front side of the tensioner when it should have been going around the back.
TWAT!
My brother just said we were routing the right way so I take that back.
I am fucked!
TWAT!
I am fucked!
Damn Cars
The only other thing I can think is does the tensioner move forwards and back, I was pulling it towards the front of the car from underneath but if it moves the other way then I can route it the other side.
I've not got the car to hand as it's down my brothers so just trying to think of everything before I have a look in a bit.
Damn Cars
Damn Cars
Yep, that's how they work, I'm wondering does it apply tension both ways as I routes it the way shown in the top pic but is it possible to route it the bottom way, if not I'm stumped.
Damn Cars
Right, it's all done.
The bottom pic is obviously correct, what threw me was the fact that I was having to pull the tensioner toward the front of the car I assumed it was moving forward, however, the pivot point is behind the pulley so therefore the pulley is actually moving up away from the belt as it should, I was not able to see which way it was moving while applying the force needed.
