bike carbs convertion vs fuel pump: advice needed
hello everyone!
i'm swapping a "2.0 zetec silvertop (feeded with zx9r ninja 900 carbs)",
into a "1.8 cvh r2a (pierburg 2v carburettor model) ford sierra sapphire".
it shouldn't be necessary, but for more info, the whole project is described in here:
https://passionford.com/forum/restor...-thinking.html
PREMISE
i assumed that the std 1.8 cvh fuel pump should feed the carbs with the correct pressure and flow... but i've always had my doubts.
QUESTIONS: anybody knows if...
-is there any chance the zx9r carbs will work correctly with the std 1.8cvh pump?
-do i need to purchase another fuel pump for this task?
-if yes, any advice about what to buy will be very appreciated, (the cheapest one and the best quality/costs one).
(the engine already runs. i started it up "on the ground" a week ago, using a mtx bike tank...)
my way would be the cheapest one:
try first, then if the system doesn't work, buy another pump (and then, which one?), but...
...if anyone knows it's mandatory another fuel pump for the task, he/she'll save me some useful time...
also, any other random advice on this one will be gladly accepted...
thanks for reading.
PREMISE
thanks for reading.
hi the cvh pump is a mechanical pump and probably wont be sufficiant, get yourself a one of these i used one on mine ran perfectly http://www.ebay.co.uk/itm/Facet-Red-...4AAOSwXshWrfqg
rooos (22-07-2016)
yes. for that price, it is definitely a good idea buying one before the swap operation...
many thanks for the tip carterhall !
rooos (22-07-2016)
many thanks for your tip too haz !
do you mean just a pressure regulator?
rooos (23-07-2016)
another good tip this one of yours...
many thanks for it, stevierob !
I dont like the redtop pump as they still need a regulator. They need mounting near the tank also.
I prefer a bike pump on the cheap or the Huco pump as sold by Webcon. It's a modern version of the su pump. You can mount it in the engine bay as they pull instead of pushing the fuel.
I've used them as a lift pump when upgrading to fuel injection as well.
http://www.ebay.co.uk/itm/HUCO-12v-e...IAAOSwFMZWtLC0
rooos (23-07-2016)
that huco is a good one. a bit more expensive, but reading the specs, looks like it's really worth it.
another great advice, thanks big wasa !
now that i have enough info, i just have to decide what way to follow...
i'll keep you posted on this one, in here or in my built thread.
i knew there were big ball technicians here on pf .
many thanks to everyone !
