07 plate Mondeo 2.2tdci ST155 eml light reset (manually reset?)
Anyone know if its possible to reset the engine management manually? i.e. with a sequence on the ignition key?
cheers Paul |
Not possible with the ignition key.
The light will go out after a successful repair (but may take a few days). |
ford
you can get vcds and cable online for mucho cheapness-re-set read codes etc
yeah just realised that I have an mot tomorrow and the light is on because I blanked the egr valve
does anyone have a the mondeo EGR wiring diagram from TIS so I can check what the wiring is and perhaps make a resistor up to fool it? its a euro4 model 07 plate cheers Paul |
© 2024 MH Sub I, LLC dba Internet Brands
