S1 TURBO CAB NO SPARK
Old May 10, 2004 | 05:56 PM
bazza's Avatar
bazza
Default S1 TURBO CAB NO SPARK
hi all
just built my cab back up an cant get it to spark the coil is ok im gettin 12v to it aswell just nowt comin out of the coil. do you think the ecu could be dead? ive put an s2 dizzy in it would this cause probs?
any help would be great as this is realy doin my head in.
thanks
barry
Old May 11, 2004 | 12:56 PM
s1 cabby's Avatar
s1 cabby
How spooky my names baz and ive got a s1 cab turbo!!!
Anyway stick a plug into you king lead that comes from the coil and make sure youve got a spark there, if so the theres nowt wrong with the ecu.
Check the rest of the leads like this and if the theres no spark on all of them then it could be the dizzy but if youve got a spark on some of the it could be a cracked distributor cap, dodgy leads or you might have too bigger gap on the plug to create a spark!!!
If ya havent got anthing comin out of the coil the yes it could be a dodgy ecu but i'd check all the connections and have a look at the alarm and immob first,
Hope this helps fellow s1 cabby turbo owner
If ya need any more help look for me at www.fordsport.netrino.co.uk coz i hard use passion ford
Old May 11, 2004 | 02:36 PM
davidnormanuk's Avatar
davidnormanuk
Hi all,
I am just about to convert my MK4 Cabriolet into a Turbo by dropping a series 2 motor and loom in it. Just wondering if you had any advice?
Dave
Old May 11, 2004 | 03:45 PM
bazza's Avatar
bazza
i dont have a spark comin out of the coil .
ive got power going to the coil.
got power goin to the dizzy(ignition on)
i think it was 2 lots of power to the ecu.
also my fuel pump is'nt buzin up either
anyone else got any ideas?????
advice to dave
it will make your life alot easier if you strip the donor car(an can hear it run before hand) its not that hard of a job you just have to hope you dont end up with a problem like mine
Old May 11, 2004 | 03:54 PM
davidnormanuk
I've already got the engine, loom etc and am just waiting on an exhaust. I just hope it all goes smoothly.
Dave
Old May 11, 2004 | 06:24 PM
richard157's Avatar
richard157
Bazza,I know this will sound stupid,but have you got the multiplugs for the fuel and ignition ecus on the right ecus.Cos they fit on both,i did this on mine and had the same prob,swapped the connectors over and it started first crank.HTH
Old May 11, 2004 | 06:48 PM
bazza's Avatar
bazza
thanks for the reply but mine are only just long enough to reach each ecu which they are meant for.
thanks
barry
Old May 12, 2004 | 02:17 PM
s1 cabby's Avatar
s1 cabby
If youve got power going into the coil and not out of it then it could be fooked, but still what loom and engine have you got in it coz ive just read that youve put a s2 dizzy in there and i'm not to sure if that could be the prob also!?!
Convertin a cabby is a piece of pi55 i rebuilt mine using s2 stuff so i had to change quite a bit to keep the s2 loom whole but providing you have every thing (I had a donor car so i knew every thing was ok) then its a stright forward job, where are you on the map dave??? Ive got a s2 s/s scorpion for sale!!
Old May 13, 2004 | 08:10 AM
JesseT's Avatar
JesseT
thanks
barry
I did this too! Didn't know then that the S1 and S2 ecus are the other way around. I just had a look from a S2 which way they go and obviously it went wrong.
Old May 13, 2004 | 08:53 AM
bazza's Avatar
bazza
tried to swap um no joy..
ive got power goin into coil out of coil the power is goin all the way back to the ecu.
the fuel pump is not buzzin up ive checked the feed to the pump an im gettin 12v for a split second when the ignition is switched.
bin told that if the pump is'nt spinin up then i wont get a spark because its on the same system.
Old May 13, 2004 | 09:53 AM
s1 cabby's Avatar
s1 cabby
Have you looked at the fuel pump relay??? Its under the dash above the driver side speaker pod
Old May 13, 2004 | 09:59 AM
bazza's Avatar
bazza
there is a silver one an a black one they both click an pump spins up when ignition is switched .
no one got anymore ideas??
JK12
33
Apr 26, 2021 12:09 PM
slammedorion
15
Nov 1, 2015 07:17 PM
carlo
24
Oct 5, 2015 08:20 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
