2.0 zetec turbo pressurising coolant
Fully forged and block and head was skimmed slightly before build, only thing i can think of is head gasket but cant understand why it would go when both faces are perfect.
I used the focus rs multi layer head gasket which was a good make, no oil/water mix but when the cap is taken off it does stink but cant describe the smell.
Any help or ideas appreatiated
Ill do that mate, Do you think its worth a quick compression test aswell?
spoke to the engine builders and they said the head was pressure tested, but just a bit concerned now as a head gasket leaking on 2 brand new skimmed faces seems really unusual
The turbo isnt plummed in to the coolant mate, on the list to be done but supose it keeps the list the problem could be down
