ford focus c max flash code 16
hi am new to this got problem that someone can help with have c max ultima 2.0 tdci with flash code 16 on have check most things also changed clocks,ecu, check plugs on kick pannel also check wireing to ecu also hard wire from plug on kick pannel to ecu an from clocks to ecu when i done ohm test on ebod plug on pins 3,11 i get 62 ohms an on 6,14 i get 2 ohms so i no there is some think on the can bus someone mentioned bout on of modules sortting can system any help would be most graveful please help also when i unplug plug 112 i think on kick pannel i get 120 ohms also when i test pins 3a 4a i get 120 ohms at ecu clock pins i get 120 ohms when all connectted i get 2 ohms help help please colin:wall::wall:
© 2024 MH Sub I, LLC dba Internet Brands
