mondeo gearbox problem
Old Mar 25, 2005 | 08:05 PM
ADSRST's Avatar
ADSRST
Default mondeo gearbox problem
hi lads im after an idea as to what may have happened
2.0 16v cable change box
my mate stopped at a t junction put the car in first gear,then pulled away, then the gear selector went loose and wouldnt select any other gear so he had to drive the car home in first gear,i went around to have a look the next day and the car is stuck in first, i tried to select a gear by moving the cable ends on the gearbox and it moved freely there is no resistance the clutch works fine and as usual
please help as he is now using public transport and it is shit
cheers adam
Old Mar 28, 2005 | 02:10 AM
GavinPearson's Avatar
GavinPearson
The roll pin is broken.
You do not need to remove the gearbox, but you do need to remove the selector unit.
It should be possible to obtain a new roll pin.
Old Mar 29, 2005 | 05:30 PM
ADSRST's Avatar
ADSRST
cheers mate ill have a look at it this weekend thanks for your help is the pin in ternal or external cheers again
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Kam B
Sep 24, 2015 10:40 AM
yorkie92
Sep 6, 2015 05:34 PM
gingeRS
Sep 4, 2015 06:29 PM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
