Transit t350 75 ps
Hi there everyone any help will be hugely appreciated
I have owned the van for two weeks wen I got the van it started on the button for first 4 to 5 days as time went on it started to crank more times before starting so cleaned all lines and replaced filter bleed diesel lines and started to start a lot better drove 300 miles plus Went out next morning and would not start at all just cranking and cranking put jump leads on after 10 mins of cranking and still nothing So out came the easy start and with a very small wiff it started straight away Runs perfect after and never seen a drop off smoke out off it Van drive and runs perfect as coverd 500 miles plus once started with easy start but as soon a I turn it off it REFUSES to start just turns and turns PLEASE HELP |
TDCI?? pump or injector problem would be my shout! DO A LEAK OFF TEST mate
It's tddi mate and thanks for reply and wen I take the return pipes off diesel just pissis out off them do I have to clamp them for the injectors to leak off please can u explain and it's the injectors with no wording the wording is on the pump
I ment wireing
The leak off pipes are solid plastic and crimped onto each injector to take them of u undo all 4 10 mm bolts and they all come off together how do I leak off test these please me
© 2024 MH Sub I, LLC dba Internet Brands
