trigger wheel mfi to efi rs turbo
I was wondering if anyone could give me some advise... I recently fitted a mfi rs turbo engine into my mk2 fiesta xr2 rep and since fitted all I had was fueling problems so I have decided to convert to efi! But I have been told to use a trigger wheel 36/1 on the crank pulley but I had a look threw ebay and they do different sizes and its says they only take certain ecu's. Would anyone know what size trigger wheel I need and if they would be ok to use with an ofab ecu? Thanks for any help! Matt :)
Originally Posted by mattxr2
(Post 6367205)
Also some later spec cvh engines had the crank sensor hole so you might be able to use a efi cvh set up, or you you could have the block machined.
Drill the hole for cps and fit efi flywheel and cps
I have a efi flywheel, helix organic clutch, and a choice of cps's In rs turbo parts for sale |
© 2024 MH Sub I, LLC dba Internet Brands
