Painting Wheels
Not to sure if this is in the right section but i'm painting a set of alloy wheels and when I primed one of the them the primer has bubbled and cracked, why would this be happening and what can I do to stop it? I have already done 2 wheels and they have turned out ok.
The paint has reacted, normally due to silcone or oil based products been used on the wheels, wait till the paint hardens then ull have to rub it right back down again.
Originally Posted by ANDYRACER
(Post 6221534)
Originally Posted by ellisjoseph66
(Post 6221538)
Do you mean rub the whole wheel back to metal or just the bits that hace reacted?
Originally Posted by davewithacossie
(Post 6221543)
spray with wd40 then a brillo pad over it should take it to a smooth serface then apply paint then primer then paint over again
Could be a number of things get a pic up if your going straight on alloy uou should etch prime first , you should panel wipe before to take off any oil /dirt, put the primer on light coats if you put it on heavy it can't dry fully and can crack , you will need clean primer off thinners or rub it off and start from scratch .
If they have been painted before can be this bubbling up when new paint eats in can be a cunt to sort you have to rub it right back and go on with nice light coats
As said can be a number of things, paint reacting with pervious paint or not cleaned off properly before priming or too heavy a coat. Did u use 2k or aerosol by the way?!
Either way will have to be rubbed back or it will keep coming back on you!! |
© 2024 MH Sub I, LLC dba Internet Brands
