turbo help needed
Old Mar 8, 2005 | 08:49 PM
matts1158's Avatar
matts1158
Default turbo help needed
i have a rs1800 and have been offered a turbo a TB03 for it serial num 0c0014a. does any1 no if it will work ok and what it is off. its on a 3 cylinder manifold so presume of a v6.
thanks matt
Old Mar 8, 2005 | 11:57 PM
GrimmeRS2K's Avatar
GrimmeRS2K
could of been off a xr4x4 turbo technics conversion, u can get most garrett turbos to fit providing u have the right manifolds,
and are you planning to run this on your rs1800 at low pressure?
Old Mar 9, 2005 | 12:05 AM
matts1158's Avatar
matts1158
i have no idea what pressure to run it at. pipework not a problem can make all up myself fabricator buy trade. didnt no if the the turbo would be to big or not how much lag etc. thanks for your reply gonna ring some companies c if they can tell me what its off and give me a bit more speck 4 it. what sort of pressure could my engine handle before it goes bang
Old Mar 9, 2005 | 12:11 AM
GrimmeRS2K's Avatar
GrimmeRS2K
from a n/a engine to a turbo engine, you will have to take it to a tuner to be setup as the ingition curve is different, dont know much about the 1800 lump but i would say no more than 6psi.
Nowadays there are alot of companies who sell thicker headgaskets designed for your conversion to lower the compression of the engine to allow a bit more boost, speak to Van alken they are good at turbo conversions on zetecs etc
Old Mar 9, 2005 | 12:25 AM
matts1158's Avatar
matts1158
i plan on getting my pistons mechined to lower the compresion. what else do i need to do to get more boost 6psi doesnt seem enough was thinking bout double that for some proper power and throttle boddies. will contact the company u advised c what they have to say.
thanks matt
big_Rad
Sep 15, 2017 09:36 AM
muz
Aug 16, 2015 12:57 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
